Has anyone tried this product? Opinions? Thanks, Nick
Nick,
Yes, I've used all three of their products and like them as do some of the writers for FWW. The only negative I have is on occasion when applying the oil to Cherry I do get some areas of blotching. You have to do alot of rubbing when applying the oil and it must be put on very very thin.
Read the message under Finishing titled "Maximum Chatoyance" and read what Paul S. has posted.
Lar
Yes I do use it and do like the finish, as well as the thought that it is a safe material to handle. The only issue I've had is keeping the shop temperature above 70 degrees, otherwise it just won't dry properly / completely.
Greg
