I just picked up a 14″ Trojan handsaw.the top guide holder is broken and the wheel rubbers are cracked.where can I find new wheel rubbers,or can I make them?
I'm not familiar with the Trojan, but have you checked out the aftermarket tires that you can get at Woodcraft or Rockler or any number of other places? 14" is a common size.
There's a parts site 2daydeliver.com that might have them. I did some brief searches and they seem to have some bandsaw tires. Hopefully they'll have yours.
Does the Trojan look a lot like the Harbor Freight bandsaw in the attached picture?
If so then it's a generic 14" bandsaw and you should be able to get parts easily from many sources. If your tires are 1 inch wide, you can even get nice urethane replacements on Amazon.
The guide assemblies are sometimes found on Ebay for cheap. You could also take your broken part to a Harbor Freight store and compare it to the display model. If it's the same, you can order from them.
The Trojan looks like a lot of 14" cast iron bandsaw clones. Urethane tires from most suppliers should do you fine. The guide holder may be a little tougher. Can you post a clear picture of what it was or where it attaches? We may be able to help.
