Hello all……..
I am considering the Apollo 1000 turbine and gun.
May I ask if anybody here is using it and if so, how do you like it?
What are the pros and cons for this machine, does it spray water based finishes. I guess what i really would like to know is does it perform as advertised?
I appreciate any info I can get.
God Bless and Merry Christmas……..
Raul S…
Creative Woods
I've have the 800 model for about four years and have no complaints. I use it mainly to spray water base laquer and poly but I've also used latex in it with good results. The 1000 should be even beter than my 800, so my advise is, go for it!
Hi,
I,ve been in the tool rental business for 25 yrs and when I retired I purchased an Appolo 1000 for my personal use.I.ve used it to spray oil base,acrylic latex,Sikkens Poly and all kinds of water based poly and heavy floor finishes. This machine is the ticket.All the others dont have it.Forget the 2 stage,yeah it works if you cut the material and weaken it. The control is great. Little overspray. I sprayed all the dental moulding on our brick home just using a hand shield and the Apolo with a paint pot.
This machine is a pleasure to use, good luck!
Joe McDonnell
