Greetings …
I’m a remodeling contractor from the other side of this board … fine homebuilding.
Currently working a remodel in Beaver, PA …
at some point I have to have some balusters turned for a new front porch stair rail.
The porch already has balusters/rail the whole way around …
would like to copy/shrink existing and build into the new rail.
I got no lathe … so … I need some wood turned.
small project … off the top of my head here … not much more than 20 pieces or so.
If interrested … email me thru the taunton site.
It’s not a rush job by any means … I’ll be at this place for quite some time.
Just one more thing on the list.
Jeff J. Buck
Buck Construction
Artistry in Carpentry
Pgh, PA
Jeff, you may get better response by contacting one of the local chapters of the AAW. Please see the chapter listings from the AAW website.
http://www.woodturner.org/
Jeff, You may want to post your request at http://www.woodweb.com/ This is a more industrial level site.
If you drag down the third collumn from the left, near the bottom, in Solid wood Machining may be a good place to start. And I think there is another place to request quotes.
Thanks Guys ...
I was just doing a quick check here before following other route.
as luck would have it ... there was just an article in our local paper about a turners club that meets at a local shop. They'll be my next stop.
Thanks again.
and ... if anyone else reads this ... the offer is still open.
Buck Construction
Pgh, PA
