I am making pulleys out of maple or ash. I think it will require turning on end-grain, mostly. Otherwise the pulley could split in half along the grain? Am I right?
Is there any special attention with turning on end-grain.
It seems that plywood is often used to make pulley. It plywood better than solid hardwood.
I also have a 3/4 inch hard phenolic plastic sheet salvaged as a toilet divider. Can it be better used to make pulleys?
I haven't had a lathe for even a year yet so not the greatest answer here, but as I recall, wooden pulleys I've seen have most all been turned on end grain.
The phenolic might make good pulleys, maybe better than the wood, but it depends on what you're trying to use them on.
You are correct.
Turning on end-grain is not easy so make sure the tools are sharp and take light cuts.
You will not have a happy result if you cheat and try to turn them like spindles. Splitting is almost certain.
