Hey all,
I’ve been turning for about a year, and have been asked to make some round balls.
I need some advise on how to get them perfectly round. Jigs, techniques, websites, etc.
Any help, suggestions you can give.
Hey all,
Springett's book "Woodturning Wizardry" has a simple effective jig for turning spheres.
Hi Ckenney ,
What size and how many do you need ?
Do they have to be perfect spheres ?
If they are not too large there is a way without a lathe .
I can only offer information with no first hand experience , I read about this in FWW methods of work like 58 years ago or so .
You cut cubes close but not the exact dimension
Orient your belt sander so the the belt is facing up. You make a box as wide as the sander and as long as the platen is flat , you place a see thru top that opens to keep them from flipping out . You will need to rig the contraption up to suit your machine .The cubes flip around and are supposed to become round , whilst the belt is in motion .
Looks good on paper
good luck dusty
I imagine you will use a screw chuck, if the work is not too large. After rounding the cylinder and marking out the ends,I use a wide parting tool. I use a 1/4" parting tool I made, you could use a bedan tool also. I have found for myself that a parting tool is better than a skew for rounds.
Practice first on scrap.Make a half circle cardboard template to check your work.The screw chuck end is another story.Part down to a narrow diameter, don't hit the screw.Remove the chuck,saw off the tenon and sand to a ball end.
mike
Make a set of cup chucks and keep turing the axis of the ball, Raffen shows it in one of his DVD's and books, not at all difficult to do.
