Hey everyone! Hopefully you can help me. I’ve been attempting to pour epoxy on to wood in a mold and ending up with tons of bubbles. I put it into a vacuum chamber with no luck. Is there some sort of chemical reaction that I am missing? I’m not talking a few bubbles. It looks like Styrofoam.
Saying you used epoxy is like saying you bought a piece of wood. Many different types of epoxy. If a vacuum chamber didn't help, find epoxy with a lower viscosity and a longer cure time. I would be looking at a cure time of over 45-60 minutes and a low viscosity, like thinner than honey (I assume you don't possess a viscoelastometer so i won't provide objective numbers)
Most people use heat on the epoxy right after pouring to eliminate bubbles.
West Epoxy 105 Resin with 209 hardener may be your friend....
Yes, you are missing something.
If you put epoxy in a vacuum you will generate bubbles as the product gets hot during curing and the vacuum lowers the boiling point of the epoxy.
When casting for turning, you need to use a pressure pot, not a vacuum. This results in minuscule bubbles or none at all.
Don't be in too much of a hurry though - most resin casts are left overnight.
Polyurethane resins bubble more than epoxies so are not suitable for decorative turnings.
AH! I did notice that the bubbling increased in the pot. Thanks!
Thanks everyone!
