I often use two-sided tape to hold wood parts together temporarily while performing other operations on them. The tape I use requires a wedge to seperate the joint afterwords. Tape residue remains. It sticks to plane blades and scrapers and clogs sandpaper. What can I use to remove the gum without hurting the wood? I have used diesel oil where it did not matter, but the oil will stain wood.
In my machine shop world we use dbl stick tape for similar purposes. We use isopropyl alcohol to dissolve the bond. Acetone is avoided because it dissolves the adhesive and often the tape substrate leaving behind a gooky mess. Once the adhesive itself is dissolved its very tough to remove.
Let us know what happens.
dave
Thanks for the information. I used isopropyl alcohol and it worked perfectly. It even removes the pencil lines and does not raise the grain. The residue that gets on your fingers really sticks hard and has to be rubbed off.
Tex, Paint thinner or lighter fluid also good for those pesky bar codes and price labels.Pill bottles I use for nuts and bolts etc etc. Stein
I have used vinegar in the past to remove labels from things I had purchased. Another trick is to heat the label/tape with a blow-drier or heat gun if you are very careful and then remove it.
Lazarus
Remeber, "Wisdom is the toughest of teachers! She gives the test first and the lesson after."
Try carpet tape. It holds real good and the sticky comes off without a solvent.
My guess is that you're using that foam dbl stk stuff. It's real nasty.
Thanks all for the quick reply. This is a great forum. The tape I used is sailmakers tape and it was old. I will try some of the suggestions and look into carpet tape.
That might be your culprit right there. It may be that your sailmakers tape simply has degraded adhesive. I've had old carpet tape get gummy and leave adhesive behind. Fresh carpet tape doesn't do that, though.
Kevin
Edited 6/20/2003 10:49:26 AM ET by Kevin
Thanks Kevin. I bet you are right. I will look for a source.
I recommend 3M #410 double coated tape. It has a paper substrate that is not going to dissolve.
http://products3.3m.com/catalog/us/en001/manufacturing_industry/engineered_adhesives/node_GSWMHNZVVDbe/root_GST1T4S9TCgv/vroot_WHG0MWH6QPge/gvel_1MWTTQ79VCgl/theme_us_adhesivetape_3_0/command_AbcPageHandler/output_html
dave
I use mineral spirits to take off glue residue from tape and those damn bar code labels. I works real well
Bill
I use Rockler's face plate tape. I can usually get the reside off with a putty knife. I used to use the thin carpet tape but I had a routing pattern slip once to often so I switched to the FP tape. It's filament reinforced so it sticks together well and comes off clean. It's so sticky that I can usually get 3 or 4 parts routed before I have to change the tape on the pattern.John O'Connell - JKO Handcrafted Woodworking
Try a product called "Goo-Gone",available everywhere, great for sticky labels and such. I've used it on unfinished hardwoods.
Enjoy, Roy
tex whats the name of the tape your using. the dbl stick tape i use doesnt, wont stay stuck i've used two diffrent products.. thanks bear
O don't know the name. It is sailmakers tape and is 1" wide with a white protective cover. It came on a sailboat I purchased used 13 years ago. I used it to mend sails and now am using it in the workshop. Possibably one of the other writers knows a brand name. I will have to check with a sailmaker.
To my knowledge there are at least two types of carpet tape, plastic-backed and cloth-backed; I have found only the cloth-backed holds well enough for use in the shop. Shel
I am using a cloth backed tape and it holds very well. I have to use a wedge to seperate the pieces stuck together. Now that I have discovered isopropyl alcohol as a solvant, I will keep using it. It can be reused, i.e. the patern board can be stuck to a new piece of wood several times before it begins to slip.
