What glue and sealant should be used with Ultralit MDF? I know that water ruins MDF, so should I avoid water-based products? Brand names appreciated!
Janet
Janet
Just use what you normally use. It's not like leaving it out in the rain.
Rick
Thanks, Rick. What type of sealant would you use? I need to glue plywood to MDF, and it's a large area. Should I seal all sides of the MDF before assembling, or will the sealant prevent the glue from working?
Janet
Not exactly sure what you are doing. I would seal after gluing or the glue won't bond as well unless you sand off the sealant to where you want to glue to. The only problem with a water based glue is the warp and balance of gluing to one side. You know the thing about gluing to both sides of a substrate for balanced construction.
Rick
I'm making a sliding shelf (to hold a computer keyboard) for a built-in desk. The drawers that will be replaced are supported by a frame of laminated MDF that screws to the underside of the desktop, so I made the shelf and its frame out of Ultralite.
This MDF doesn't have plastic laminate on it, so the shelf needs to be surfaced with something smooth and durable. There's a piece of 1/4" birch plywood in the garage, which I will glue to the top of the shelf. But that leaves the shelf unbalanced, so I plan to seal the MDF--in the hope that sealant will keep it dimensionally stable.
Will this work?
Janet
Edited 12/8/2002 10:16:24 PM ET by DWREAD
That's a fairly small piece so it should be ok. It might warp a bit if you use a water based glue. Why not just paint it or laminate both sides with formica. I was originally thinking you were doing something much larger. Seal it right after you laminate with the birch ply.
Rick
