I’m getting underlined titles for all the threads on the message list. Suppose it doesn’t make that much of a difference, but it does make it a bit difficult to read, which in turn irritates me to no end, which causes me to smash my monitor, which makes an awful mess and hurts my pocket book, which in turn irritates me to no end…….
Solution?
Sounds like you need the turn off the anger button, anger won't help change anything.
Jeff K,
Go cut some dovetails in plywood with a jig...it'll take your mind off the monitor real quick...
Put some pressure treated lumber on your TS for a couple of hours....that'll give you other things to reflect on...
BG. Thanks; this is scary. I was just about to leave for the lumber yard to buy some pressure treated lumber for a deck - that is some nasty stuff to work with.
Forest Girl. Thanks for the link. Be sure that I will write to them before this drives me batty.
Jeff, I hadn't noticed the change, but if you want to get attention from the PTM (powers that matter) send a note to forumhelp@taunton.com
Prozac?
FWIW, if you're using Internet Explorer, there is a setting that allows you to remove the underline for all links. Go to Tools -> Internet Options -> Advanced and scroll down to Underline Links. You have the options to either display underlining for links only when your mouse hovers over the link, or to turn it off completely.
Edited 6/20/2003 6:53:10 PM ET by dan48g
