For those familiar with either KV or Blum undermount, soft-closing type drawer slides, is it ok to cut the drawer back of a dovetailed drawer box such that a notch would not be required to accommodate the undermount slides? I typically raise the saw blade on the last pass while cutting the slot for the drawer bottom and cut the back so it will rest on top of the drawer bottom, so there wouldn’t be a notch in the back but the same clearance would exist for the drawer slides. As far as I can tell, the notches are only required if the drawer back dimensions match that of the drawer sides.
Thanks for the advice,
Brian
It's fine for a drawer back to sit on top of the bottom. Makes it a lot easier to slide the bottom in and square up the drawer with all types of drawer construction. The bottom gets attached to the back with screws. It's not unusual for the bottom to project past the back a little, too. Then your screws aren't right on the edge.
The undermount drawer slides I have seen to have the bottom of the drawer sit on the slide.The slot in the back is to hold the drawer in place. I am not sure how you would do it without the notch. If you found a way to hold the back of the drawer to the slide, would you be able to take out the drawer?Domer
All ,
For the blums , The drawer back can either be notched or stopped at the top of the bottom . The 6mm - 1/4" hole drilled in the back of the back is what keeps the drawer box from tipping down as well as indexing the box into position.
The slot is not for holding the drawer box in place the hole in the back does that
regards dusty , boxmaker
I misunderstood the question. The undermount slides I use have a clip in the front and the hole in the back. I assumed the slot being talked about was the hole in the back. Domer
