I glued a small door with hide glue, with the idea I might have to alter it later. I used Titebond Liquid Hide Glue. Is it possible to disassemble the door without damage?
I would check with Titebond to find out what they recommend. I checked with the epoxy company when I needed to get a mortise and tenon back apart after the epoxy had set up. They told me to get acetone into the joint, which I was able to do with a pin hole and a syringe.
I think in general hot water softens hide glue.
Good luck!
Generally speaking water and heat are the most detrimental to hide glues. So that would be my start point. Get your heat gun, some water and a scrub brush and have at it.
Heck it might be easier to rebuild!
Steam and a jig to apply pressure is how a luthier removes a guitar neck fastened with hide glue.
I use a damp face cloth ,hold your iron on it, it takes a few wetting and heating, It works. I use this method every once in a while in restoration repairs.
That works like a charm! Thank You for that tip or sharing your knowledge!
Hide glue ( I don't know very much about hide glue from a bottle, but it says "hide glue") should release at approximately 200/220 degrees f. If you can heat both sides of a large joint at the sametime, like with a couple of heat guns or a couple of irons. I have both.. My iron(s) is about right for that temperature at the " linen" setting. I use cloth between the wood and the iron, it shouldn't burn at that temperature but I often dampen the cloth and use aluminum foil under it to keep the finish or wood from getting wet. A heated knife can be helpful. I keep a couple of knives on a hot plate-- they should be stiff and not sharp. I made a couple from some sort of pastry knives (big butter knives actually) I found at a goodwill.( Also a good source for used irons.) Don't use the wife's cause after your done she'll tear you a new one! A couple of heated pallet knives 'cause they are thin and flexible. You heat the wood until you think its hot through and through and I found that a slow steady pressure like from a clamp or clamps in reverse works the best. A rubber mallet and a beater block sometimes used cautiously can be useful. Since it's a door you have top and bottom joints and maybe a center rail. Unless you went around the neighborhood borrowing irons you can only do one joint at a time. Get one to move and go to the next joint. When the glue cools it will reset so you go a little at a time from joint to joint and back again.
Steam works once you work out a rig and can get space to get inside the joint. I made a small steamer once out of a old coffee maker.. I have a special clamping rig I made for removing instrument necks- same process,heat and steady pressure but it's only one joint and it's not big. BIG,BIG deal if you screw up though!
Yes, I used a heat gun and putty knife just the other day to pull a piece I had installed with Titebond Liquid Hide Glue.
It worked just like regular hide glue.
Worked like a charm! Thank You for sharing info.
Thank You everyone for your helpful tips!
