I recently acquired enough yellow limb to build a “Krenov” style cabinet that I’ve been wanting to build. The cabinet turned out very nicely (if I say so myself) but one month after it was finished, one single leg on the cabinet has decided to ‘toe-in’. The legs themselves are 5 feet long, with a long gradual curve or splay to the outsides of the cabinet. what has happened, is that one of the front legs is turning to the inside of the cabinet, so far it is one quarter of an inch, but it doesn’t seem to be stopping. The dimension of the wood is quite significant, being 1.5 inches by 2.5 inches. Are there any tricks out there that will help me stem the progression of this or even reverse it?
I can't think of a simple solution off-hand, but how obvious is it? Anyway, here's a thought. Can you get into the back of the leg with a router, a fence, or jig and straight bit to work a channel, or channels, thus weakening the piece, straighten the thing, and glue in a new piece of matching timber with a non creeping glue such as urea formaldehyde. On the other hand it might be best to leave it alone if it's not readily visible to the eye. There's a chance it will move back into the 'right' place later. Not much help I fear, but you never know. Sliante.
*Amputate. That is one way if you can't live with it. Use a piece of the same wood and replace the "toe-in" section using a scarf joint. Krenov's pieces are generally light (color) if I remember correctly. I'm not familar with that wood. Anyway, if it has any grain etc. you could match it as closely as possible. A long scarf joint would give ample long grain to be strong enough. The splice may be hard to blend. However with artist brushes and pigments its amazing what you can blend, especially if there is any figure to the wood.
