I ready the email from Fine Woodworking regarding the benefits of using Urea formaldehyde glue for bent laminations. It does not mention if this glue is waterproof. I am planning on constructing a small bridge for my back yard and naturally it will be exposed to all sorts of weather here in New England. Can you recommend a glue which is as easy to work with as Urea formaldehyde but is waterproof? Thanks.
Hi, Walterboy—
Urea glue is waterproof, and does well surrounded by moisture. However, it's brittle, and your bridge will do much better with a slightly more flexible adhesive, such as epoxy, which is also waterproof.
I would recommend a two-part marine epoxy (made for wood), such as West System, for your bridge. Two-part epoxies fare better in the weather, expecially those that are formulated to do so. The people at West System design their adhesives to hold wooden boats together (immersed in fresh and salty water) so it shoud be good enough for us mere bridge-building mortals!
Best o' luck on the project, and post a photo or two when you get the chance.
—Andy
Edited 6/14/2007 9:16 am ET by woodrae
Thanks very much for your help in this matter..............Walter
