Hi
I am a furniture designer in New Zealand. I am shortly going to be in the process of converting some of my designs to use timber that is readily available in the United States. I can not seem to find a definitive list of what sizes of timber is commonly available.
My current designs use dressed pine (I think in the States it is called dimensional) and in metric sizes. I wish to find the nearest US equivalent for them. I would wish to find a close substitute as I don’t want the users of my plans to have to rip the timber to the correct size.
If anybody could give me some pointers to a definitive list it would be most appreciated.
I am thinking of mainly Pine and available in home improvement stores like Home Depot (which is the only one I have heard of. I am sure there are others)
One of my plans has been designed utilising the following materials
Dressed Pine 1″ x 4″
Dressed Pine 1″ x 9″
Dressed Pine 2-1/2″ x 2-1/2″
Dressed Pine 2-1/2″ x 3″
Are these materials available in the States?
Victor Pringle
lumber sizes
The two main "home improvement" chains in the U.S. are Home Depot (www.homedepot.com) and Lowes (www.lowes.com). You can research their sites for sizes they typically sell. Most of the stock is limited to "S4S" (surfaced four sides) 4/4 - about 3/4" in thickness, with common widths including 4", 6", 10". From there, commonly-available stock jumps to "4x4" fence posts. But, it is difficult to find stock worth using for furniture due to their sources and storage methods. Specialty lumber stores will have wider selections, but 8/4 (1 3/4" S4S) is often the limit in thickness.
nominal size vs actual size
Lumber Dimensions
2x4s are not actually 2 inches by 4 inches. When the board is first rough sawn from the log, it is a true 2x4, but the drying process and planing of the board reduce it to the finished 1.5x3.5 size. Here are the common sizes of lumber, and their actual sizes.
Nominal
Actual
Actual - Metric
1" x 2"
3/4" x 1-1/2"
19 x 38 mm
1" x 3"
3/4" x 2-1/2"
19 x 64 mm
1" x 4"
3/4" x 3-1/2"
19 x 89 mm
1" x 5"
3/4" x 4-1/2"
19 x 114 mm
1" x 6"
3/4" x 5-1/2"
19 x 140 mm
1" x 7"
3/4" x 6-1/4"
19 x 159 mm
1" x 8"
3/4" x 7-1/4"
19 x 184 mm
1" x 10"
3/4" x 9-1/4"
19 x 235 mm
1" x 12"
3/4" x 11-1/4"
19 x 286 mm
1-1/4" x 4"
1" x 3-1/2"
25 x 89 mm
1-1/4" x 6"
1" x 5-1/2"
25 x 140 mm
1-1/4" x 8"
1" x 7-1/4"
25 x 184 mm
1-1/4" x 10"
1" x 9-1/4"
25 x 235 mm
1-1/4" x 12"
1" x 11-1/4"
25 x 286 mm
1-1/2" x 4"
1-1/4" x 3-1/2"
32 x 89 mm
1-1/2" x 6"
1-1/4" x 5-1/2"
32 x 140 mm
1-1/2" x 8"
1-1/4" x 7-1/4"
32 x 184 mm
1-1/2" x 10"
1-1/4" x 9-1/4"
32 x 235 mm
1-1/2" x 12"
1-1/4" x 11-1/4"
32 x 286 mm
2" x 4"
1-1/2" x 3-1/2"
38 x 89 mm
2" x 6"
1-1/2" x 5-1/2"
38 x 140 mm
2" x 8"
1-1/2" x 7-1/4"
38 x 184 mm
2" x 10"
1-1/2" x 9-1/4"
38 x 235 mm
2" x 12"
1-1/2" x 11-1/4"
38 x 286 mm
3" x 6"
2-1/2" x 5-1/2"
64 x 140 mm
4" x 4"
3-1/2" x 3-1/2"
89 x 89 mm
4" x 6"
3-1/2" x 5-1/2"
89 x 140 mm
I did a cut n paste of this nice table in three columns but it seems to post as one long list of sizes. When I go to edit it looks right but reposting has the same problem. If you search on nominal lumber you will get better results than this mess. Sorry.
EDIT: Now that I look at it I see that the information is all there, just in groups of three.
first nominal then actual then metric.
Home Depot and Lowes
Those two home improvement stores in my part of the country, Northern Virginia on the east coast of US usually have three kinds of dressed lumber. Pine, red oak, and maple. They sell by the linear foot, not by board feet. Most of the stores will cross cut lumber for the customer for free but no rips. Plywood they will crosscut or rip. That's one or two cuts of course, they won't cut out parts of a project for you but it's nice to be able to put longer boards in shorter cars.
EDIT: Add poplar to that list of dressed lumber
You say you don't want the folks buying your plans to have to rip lumber. That is such a basic part of woodworking. If you are going to build furniture you certainly have a table saw. Not every woodworker has a planner and jointer so I can see wanting to use dressed lumber, but no ripping? Are these plans for outdoor furniture?.
