This may not be the right forum, but I thought I’d throw this question out.
I am doing some remodeling on a three season screen porch and need to replace the treads on the steps leading down to the porch. I am considering using red oak with stain and sealer but am wondering how it might hold up out in the elements.
Anything I should be concerned about here?
Thanks in advance.
Cheers,
Velo
Ipe sounds like a perfect wood for your application, hard as nails, dense, fairly inexpensive, commonly used for decking on outdoor decks. Eventually weathers to a silver gray..
Red Oak is definitely not a good choice, but white oak would be fine.
Most use either pressure treated or cedar, but other species would be ok -- depending on what is available to you locally. You could also use one of the composite materials now widely available for decking.
John Wooden 1910-
V,
Is iroko or teak a possibility where you are (I know they are expensive in some locales)? Both are durable so won't rot outdoors; but they also have a lot of silica in them and have a reputation as hard-wearers - ideal for steps. Certainly iroko is used a lot in Britain for those bare-wood indoor stairways, because it wears so well.
White oak, ipe fine for outdoor use. Red oak will rot quickly. Luan may be okay, never used it for treads, but it is used for boat trim and used to be used for hulls before fiberglass was used.Redwood and black locust, not readily available everywhere but suitable for outdoor use. Ipe would be my personal choice,
mike
Red oak will rot.
White oak (many a clipper and ship of the line was made from it), pressure treated lumber, ipe, teak or mahogany. For something less expensive, the composite materials are pretty good.
Cedar and fir are both rot resistant, but fairly soft, and may not wear well as treads.
Glaucon
