I came across a lightly used Unisaw circa early 90’s. The model number appears to be a 34-802. New models seem to start with a 36-. Does anyone know, is this saw 2 generations back?
The saw is in storage and the owner has not been able to locate the front rail. Can this be replaced or do you have to get a new table?
Thanks in advance.
You don't want the front rail anyway since you really want to replace the original Jet-lock fence with a modern fence such as Beisemeyer or Vega. The new fences are likely to bolt into the same holes as the original, and if not, it is easy to drill and tap new holes in the existing top.
MScott ,
Go to http://www.deltamachinery.com and give them the serial # and let them tell you the date it was made .
If the price is right and you need the saw , by all means buy it now . If the front rail is not found , no worry as has been suggested purchase one of the better fences , or order a replacement from Delta .
good luck dusty
Thx. Missed this one. Went for $1,100.
Hello MScott,
Not to worry, $1100 is a bit steep for a used Unisaw, especially since it is missing parts. If I were going to spend that kind of money, I would save a few more and go new. I think 50% of the original cost, for anything used, is a good deal. Hang in there, another will come along. Best of luck.
Bob, Tupper Lake, NY
