Looking for a used variable speed drill press….Any idea of where to start the process?
Lots on ebay.com
Consider a three phase belted model and adding a VFD and you will get variable speed as well as doubling the motor's speed and for 1 hp and under they will run off 120 single phase. I've seen a Baldor VFD at my local motor repair that I'm describing. Three phase tools are typically cheaper.
Edited 3/19/2006 3:57 pm ET by RickL
Three phase isn't usually available for residential customers, though.
You are missing the point. A VFD will convert single phase and three phase machines are typically cheaper. The VFD also will allow the motor to be infinitely variable and can double the motors rated rpm. You can get a VFD for less than the difference of a single phase variable speed industrial drill press. A VFD will only work on a three phase motor. Knowing about VFD's is very useful and important information for the many shop applications.
Check out this as well... http://coastaltool.com/cgi-bin/SoftCart.exe/a/delt/dp350.htm?L+coastest+dkdj2165ffc307c3+1142378416
Edited 3/14/2006 10:34 am ET by RickL
I already posted this recently, a DC motor with a speed controller works fine. Cheap too!
C.
DC motor brushes x saw dust =motor repair
VFD + three phase tecf motor x saw dust = no problem
I was a maintance electrician in a printing plant with loads of dc motors and paper dust same as fine saw dust I spent a lot of time repairing shorted armatures and worn brushes now I work in a chemical plant lots of three phase and vfd and fumes and dust not to many failures from dirt on three phase motors
Jerry
ps we make glue for RV builders
Permanent magnet DC motors have no brushes.
Routers have brushes, I have used my router day in and day out for decades, all I had to do is replacing worn out brushes.
I still think a DC motor is as good as a 3 phase motor at a fraction of the cost.C.
Where are you getting pricing so low on DC motors? In my Graingers there is a 1 hp DC motor and control for $650. I can buy a VFD for around $140 and three phase motors are available from a scrap yard for next to nothing. Most of the lathe manufacturers are using VFD technology for their drive systems as oppposed to DC motors. Aslo most industrial machines are three phase so why go the extra expense of a DC motor and controller when a VFD will do the job and cheaper. I don't see DC motors as being any cheaper than a new three phase motor.
Edited 3/19/2006 4:44 pm ET by RickL
Try http://www.surpluscenter.comC.
Yeah... I buy from them. 3 phase motors are still cheaper than DC motors. VFD's from http://www.factorymation.net/s.nl/sc.2/category.13/.f are really priced well, so I can still do it cheaper with 3 phase motor and a VFD.
Obviously your mind is made up and I don't want to try to impose my way of thinking upon you, but for the rest of you guys out there interested in having a variable speed drill press at a fraction of the cost, you can buy a 2 1/2 HP DC motor for $21.95 and a controller for $29.95 at Surplus Center, add $10 at the most for a potentiometer and a reverse switch and a few bucks for shipping... you guys can do the math.C.
Can you link to the 29.00 controller, I went to their website and the only controller I saw was 140.00
It's item #11-2449, here are the specs:
Input: 115 VAC
Output: 0-130 VDC
8 amps continous DC output @ 10 amps AC inputC.
It is unfortunate that there is such a misunderstanding of Rotary phase converters and VFD,s. I agree with you completely on your initial suggestion.
Brian
Not only on VFD and rotary converters, statics as well. And there's a new game in town. http://www.phaseperfect.com A bit more expensive but allows more than one machine with different hp ratings at a time.
A few folks totally missed the boat on what I was talking about. Oh well...
Edited 3/20/2006 8:36 am ET by RickL
