I am thinking of using 5/16″ brass round stock to pin the tenons on the arms of my Morris chair. I am going to file small grooves in the stock and use epoxy.
Has anyone tried this? Just wondering if any problems may arise.
slop,
are the grooves to allow the glue to move along the dowel? if so, sounds like a good idea. i have epoxied metal into wood many times. i know of furniture with metal, (brass,silver,copper and pewter), inlay. are your dowels/pins going to be exposed? i, for one, think that would look very good.
eef
Actually I was thinking of putting the grooves across the pin, all around to hold more glue and avoid any chance of the pin coming out or loosening. I am going to tap them in flush with the edge of the arm.
slop,
i did not mean to suggest that the grooves would be visible, that would look weird. epoxy is pretty amazing stuff. just a few grooves should give the assembly enough "tooth". with the ends of the brass sanded flush, it should look quite nice.
eef
I used brass pins in these saw horses. I did not use any glue etc. I wanted to be able to replace the top rails if I wanted to. Drilled for a snug fit and pressed the pins in using my drill press. Kind of like nailing them together but in slow motion. Worked great !
A couple of them I made the pins the exact length to be flush and a couple I made the ends domed and standing proud of the surface.
One pin per joint pressed all the way across.
Of corse the ultimate is to draw bore and use a wet oak pin. It totaly locks the joint .
roc
Edited 11/3/2009 11:50 pm by roc
You don't have to use epoxy, you can use liquid hide glue. Just make sure you etch the brass with a clove of fresh garlic.
Stephen
stephen,..."etch with a clove of fresh garlic."how pleasant that would be. what a simpler world that describes. you wouldn't be yanking our umbilicals, would you?
eef
True story, the special acids in fresh garlic will etch the hardest metal and give a good key for the liquid hide glue to grip. All of this is covered in my latest book Hide Glue - Historical & Practical Applications 2009. I am not sure if I can plug my own book, does that violate the rules here?
Stephen
steve,
plug.
eef
>special acids in fresh garlic will etch the hardest metal<Does a job on my stomach as well. That is about the only thing I don't dare toss down the hatch.Torpedos be dammed; glad to know about your book !rocGive me six hours to chop down a tree and I will spend the first four sharpening the axe. Abraham Lincoln ( 54° shaves )
Plus, the residual garlic is good for werewolf suppression. ;-)
I've used brass dowels and have chiseled barbs along the dowel's shank so that they're prevented from pulling out.
Gary W
gwwoodworking.com
