Is anyone out there using Osage Orange in any of their projects? I know it better as hedge apple, or just ‘hedge’.
Just recently I learned how durable (and awesome in a wood stove/fireplace), rot/bug resistant it is, and was curious how hard it is to work with?
As a kid that stuff was just a PITA to run into or mow around. Grew like a weed and was hard to get rid of. I can remember farmers complaining about dulling their chainsaws on it. Don’t see it much anymore in my immediate area.
John: This is a very durable wood.It works fairly easy when it is green.In my boyhood on the farm,my uncles used it for single trees and double trees for their horse drawn equipment. As I remember,the metal fittings were fited and installed while the wood was still green.There was virtually no shrinkage on drying,so the fitings stayed tight on the ends.
It makes a very fine mallet for work with chisels and carving tools,I have also used it to make a few "billy clubs" for friends in law enforcement.Thank you,Mr.Croney,where ever you may be.
Work safely ¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬
Edited 10/8/2004 6:23 pm ET by Pat
The wood is bright yellow when you first cut into it green, but it oxidizes to various shades of brown. It is in the mulberry family which is less dense wood but is also yellow. Bois D'Arc is the name that the first french explorers that came down the Mississippi River from Canada in the late 1600's gave it. That supposedly means Bow wood.
I read an article a while back that said it once was much more widespread in range, but had shrank back to Ark, Ok, an Tx because the mastodons, and woolly mammoths were the main distributors of the seeds, which as you all know had become extinct.
My dad was the son of a blacksmith farmer was born in 1910 said that it was one of the favorite woods for wagon wheels, and even some of the first auto wheels.
The largest one in Arkansas is at Arkansas Post which was the first settlement in Arkansas.
I was in a shop that worked with osage orange. A table that one guy made had a chatoyance under the display lights that was very striking. But it is a PITA to work with, as it was almost impossible to get a board more than 3-4 inches wide. You get a lot of wasted material milling it for casework.
I don't remember ever seeing it listed in a plant catalog. Is it available commercially, or do you just find someone with the apples lying about?
There are male, and female trees.
The females are the ones that have the big ball.
Hedge Apple , Osage Orange, Bois d' Arc
There are still Hedge Rows in the Ozarks, it grows every where
The Wood is very heavy & hard and as you know , few woods have a higher Density, Hedge fence corner post can last 50 to 100 years in the ground.
One use for Hedge were Bows - highly prized by Osage Indians , French explorers named it Bois d' Arc which means " wood of the bow "
I have made bows from it , and makes the best all wood bow.
If you have worked with Hickory , Hedge is like the worst gnarly knotty heartwood hard as a rock Hickory you ever worked.
Lots of wild grain, drying cracks and splits , tons of knots , will for sure dull tools. Be careful on the saw will bind on the blade, Bandsaw or Table saw.
I have turned Hedge on the Lathe you need sharp tools , makes a great Mallet Head.
Gluing ?
Ron
