My Christmas present to my sister: Make her an island for her kitchen – she pays for materials. She lives 2 hours away, I have Subaru outback for transporting said item. We both saw and liked a plan for an island found on the web that uses knock-down barrel bolts and nuts for the joinery. This would make it easy for me to transport to her. Been looking on the net for some additional guidelines for using barrel bolts and nuts and haven’t found any. Help? I’m wondering about how the holes for the nuts get made and what to watch out for. Thanks
1) Buying the hardware. Search for CROSS DOWELS. Turns out barrel nuts are actually called cross dowels. The most common size are for 1/4 20 bolts which works out ok if you're building with 3/4 plywood.
2.) You need to be able to drill perpendicular holes on ends and edges. This can be tricky without a drill press or angle guide (http://www.amazon.com/General-36-37-Precision-Drill/dp/B00004T82L).
As long as you're confident you can mark centers for your holes and then drill them square and/or perpendicular as needed, it's pretty easy stuff.
If you're planning on using regular hex head bolts, you may want to counterbore your bolt holes so you can put in plugs to hide the bolt heads.
They sell connector bolts that look pretty nice that don't require washers.
You might check http://www.rockler.com/tech/31815-864.pdf . It has some decent diagrams showing dimensions and part numbers.
As with any construction, make sure your edges are nice and square or you won't end up with a square case.
Thank you VERY much. I went to a store and held the hardware, this helped me visualize. YES, being able to drill perpendicular holes seems essential. No wonder the directions I found talked about building a jig. I might be able to use a drill press - I'll ask around. Plugs are a great idea.. the heads are the only down side of this plan.
Thanks again!
