Hello. I’m going to make a small clock out of cherry or walnut, and I’d like to paint a design over part of it. I’ve only ever used finish (usually General Finishes Arm-R-Seal) on nice hardwood like this, so I’m wondering how I can incorporate paint. I’m thinking of using white or cream paint to paint silohouettes (sp?) of trees on the lower portion of the clock, and then put finish over the entire clock. What kind of paint should I use, and will finish go over it allright? Thanks in advance,
Janine
Janine, I think the quickest and most accurate answer will come from someone experienced in the arts and crafts area. Call you local arts and crafts store and see what they recommend and have in stock. I have used waterborn acrylic enamel under wipe on poly with no ill effects but I would still check with the arts and crafts store before trusting it to work for you.
Steve - in Northern California
Janine,
Most paints will work fine under most finishes. Oil paintings are often coated with varnish. I've used acrylics under both shellac and varnish.
Off the top of my head the only trouble combinations I can think of would be gouache, milk paint or watercolors under a water based finish (obviously) or shellac. I would be very careful with any water based paints. Any kind of moistening of those paints, even if it's not water, can cause them to run and bleed. But lots of troubles with softening and smearing can be avoided by spraying the finish instead of brushing.
I would also be hesitant to put lacquer directly over any paint. The solvent in lacquer can soften, smear or even remove many paints. But it might be possible to insulate the paint from the lacquer with an intermediate coat of shellac.
As always, the very best advice is to experiment. Don't take my--or anybody's--word for it.
Alan
Thanks for your replies. You're right, though; I just need to experiment a bit with this.
Janine
