Gentlemen (and ladies?)
Some years ago I built a woodworking bench with intent to do some furntiure but, although I have done some, have used the bench little over the years. This bench was made starting with a 2.5 inch thick glued solid maple counter top that I rescued. The bench has 4.5 inch depth skirts (quite thick), is 6 ft. Long by 26 inches width. It has a front vise, end vise (with blocks) and stops (steel) and at the rear, tool slots. See pics. The trestle base is constructed of heavy, stable Pine. Overall, the whole thing is soild and like a rock. (My movers were a bit flustered with hauling it). I do need to clean the metal work some as it has been in a garage and subject to some humidity, but the vices work fine, and possibly light sand and refinish the wood. Although on a budget, I put heart and soul into this project and it looked like a piece of fine furniture when done.
Due to some financial issues I am thinking to sell this bench. I was once, ten years ago, offered $1000.00 but turned it down (too soon after building when it looked fresh and new). Would the community chime in on what you think this bench would be worth on the market. I don’t want to dump it because when I reach retirement age…who knows.. might get back into it. If in the market and did not want to build your own, what do you think you would pay for this bench. I am located in the D.C. Suburbs (since I have seen discussion of folks traveling some distance for a nice bench).
bench buying
Take a look at the other benches that are available commercially from places like Woodcraft. That will give you an idea of what the market is for "new" benches - typically $500-$1500, depending on size, etc.. Ultimately, however, your market will likely be limited to your local area - that is, those close enough to drive to your location and load it onto a truck with the help of a few friends, young and strong. Just my opinion, but it's not likely that you'll get anything close to what it is actually worth. If you own your own home, and plan to retire there, keeping it for the future may be a better option. Note that I'm already retired, so I might be prejudiced. ;-)
bench value
Thanks. Similar comment to what I have seen, but they had more to do with Commercial made benches such as the Ulmia. As mine is home built I'm not sure what it might fetch. I will take a look at Woodcraft as you mention. And yes, I do understand your other comments as well. I recently sold my old boat which I had done a lot of work to upgrade and keep in shape and it was sad to see it go.
Well, I am "pre-retired" as I like to say. My industry (civil engineering) has taken a huge hit and I was laid off some time ago. Hence my need to sell off some things and just generally lighten up the accumulation around the house. Perhaps I'll set a price and float it on Craigslist to see what happens.
Thanks again
Bench Value
Like the other poster, I doubt you'll get anything close to what it's worth unfortunately. Nice benches like that don't come up much on Craig's List, but one did pop up in our area of Sacramento a couple days ago and the listing is still active:
http://sacramento.craigslist.org/tls/1964738960.html
It looks like a great deal to me at $800, but I'm curious to see how long it takes to sell.
David
Hmm, That's a nice one.
I did look at Woodcraft and based on the different models, figured price, if new, probably in the range of $800-$1000, but one has to find the right buyer of course. If I decide to sell it, I'll have to clean it up some to give it that "new" look.
I'd take no less than 1250.00 Anything less would be a crime. If it takes 2 years to sell that is okay. Marketing is cheap these days. The material has got to be worth 600.00.
Ed
Bench Value
Thanks Ed. That's optimistic thinking as far as price. The main slab on this is 2 1/2 inches, significantly thicker and heavier than what I see elsewhere so VERY stable. The edge skirts are also thick, and it's all rock hard maple. I do need to spend a bit of time cleaning it up some, but I am in no rush as far as selling. Already gave up my boat recently, but this I built completely with my own hands so reluctant to let her go. On the other hand, the pics don't show all the stuff usually in my way of using the bench. Not enough room in my garage for all my tools and what not.
if you need the cash and have to sell it. then put a price on it to move it, otherwise you will be doing this for a year. if you are going to clean it up, then clean it up and piut a price on it. as it stands you have already exposed it, so just put a price on it that reflects it's condition and get on with life
ron
