The paint should be enough.
Pete,
Why are you considering putting varnish over paint? I've seen it done for various reasons; I'd like to know yours before trying to answering your question.
Alan
I'm wondering if it will add any particular depth to the finish, and I don't know if varnish might add more protection.
Pete,
I'm unsure what you mean by "adding depth" to a painted surface. Varnish could certainly add gloss to a dull surface or tone down a high-gloss paint, but then a gloss or semi-gloss paint would do that too. But perhaps I don't understand what you mean. Please let me know.
I also think varnish over paint would add another difficulty because varnish itself has color: most varnishes have an amber cast of varying degrees; and poly, to my eye at least, still has a greenish look. Depending on what color is under the varnish, the piece could wind up with a beautiful finish, or varnish could turn a a nice color to mud.
As to protection, varnish would protect the paint beneath it a little bit--but so would another coat of paint.
I hope some of this helped you answer your question.
Alan
only real reason to varnish would be if youre applying a glaze over the paint or wanting to change its sheen (which is best done with another coat of paint)
I routinely brush on one coat of water-based polyurethane over alkyd paint -- but only on surfaces subject to scuffing and abrasion, such as shelves in a bookcase.
I doubt there would be much advantage to varnishing something like a crib.
I assume you are aware that, generally speaking, oil or alkyd paints take some 30 days to fully cure, and thus reach their maximum hardness.
