OK, here’s a question that may be rather basic. I am applying an oil base stain to a floor. I will follow this up with 1-3 coats of shellac to add some more color and to prevent subsequent varnish/oil from lifting the stain. Is it necessary to scuff the shellac prior to application of the the varnish? I realize that doing so might give me a smoother finish but I want to know if it is necessary for proper adhesion. I always read that shellac adheres well to most anything and that other finishes adhere well to it.
My preliminary tests show that the varnish adheres well but I do not know how it will hold up over time.
Anyone have experience with this?
mlb,
The first shellac coat will raise some fuzz which you can lightly take down with a screen or abrasive pad on a buffer. You don't have to scuff the subsequent shellac coats for the varnish to adhere.
VL
I think the best varnish for floor applications is poly. Unless you use dewaxed shellac you may have adhesion problems. Non-poly varnish can be used over shellac but it may not wear as well.
I agree with the poly vs alkyd varnish on adhesion and toughness, however; we never wear shoes in the house. My old house had oil/varnish blend finish on floors and they held up very well. I will use either wiping varnish or oil blend. I am not much on a thick-film finish. I realize they can be tough but I don't think they look so hot and it can be difficult to spot repair.
