On todays show of rough cut he sprayed the veneer with a solution to make it soft and pliable.
what is the spray he used
veneer softener
Veneer Softening Solution
3 parts water
2 parts whie or yellow wood glue
3 parts water
1 part denatured alcahol
1 part glycerin found ar food stores and drug stores
no shipping
vacuume pressing system.com very fine veneer forum
good luck and Happy Halloween from Salem Mass
veneer softener
Constantines sells one that works pretty well, pre mixed. You can make the above mixture with hide glue, which is what I have done in the past. I would be a bit concerned that he yellow or white glue could affect the finish.
Thanks.
Jay
Joe Woodworker
Joe's site is great and he sells top notch veneer. He is also a great wealth of information. I built my vacuum press from his plans and bought the parts as a kit and it works great. His softener will get the job done. He ships quick and is easy to work with. I've sent numerous questions to him about doing some bubinga (screwing it up would have been expensive) and his tips worked great.
http://www.joewoodworker.com
This is a link directly to his sofenter at veneersupplies.com (his site as well)
http://www.veneersupplies.com/categories/Veneering__Supplies/Tools__%26__Supplies/
