What is the best adhesive you would recommend to glue maple veneer to MDF or pine. Is PSA backed veneer OK? Can I use a water based stain to color the veneer?
Good choices are hide glue, PVA, and urea formaldehyde(sp?) types, plus one or two others. Contact cement, of which PSA is a type, is generally a poor choice being too soft, thick and liable to lifting in use.
Water based dyes and stains are well suited to colouring almost any timber (or veneer) including maple. Slainte.
Thank you Sgian. I started my woodworking hobby about a year ago so any input regarding working with veneers is mostly wellkome.
I went through your gallery and frankly, Sgian, I am impressed. Your work looks just great. I am 69 now and it is a little bit too late for me to start learning all the secrets of woodworking profession but I'll do my best. Thanks again.
Janusz
Thank you guys. As I was telling Sgian I am new to woodworking and your suggestions are of a great help to me.
Taking up a new and serious hobby at age 68 is indeed admirable. Have fun learning.
Thank you s4s. I just love it.
Shatzo: Never too old to begin anything - it is just a mind set. I think the most important thing to do is to keep being productive and to challenge yourself in any way. Wood working is one of the most rewarding hobbies that can be shared with others and fulfills those requirements. I hope to hear more from you in this forum.
Marcello
The best adhesive would be Urea resin. Why? Reduced springback, the natural characteristics of Maple (tight grain and tension). I do not recommend PSA. I have a nice adhesive seleection guide of my web site.
http://veneersystems.com/supplies_02.html
Any questions, drop me an email -
[email protected]
John Ersing
Hide glue tops my list. Any bleed through will not affect staining whereas PVA and most of the rest will.
My list in decending order,
1.) Hide glue, either hot or liquid, it depends on the need for open time. In a press I use liquid, for hammer veneering i use hot hide glue.
2.) PVA (Yellow or white glue), because it's fast, I use a press and sometimes like the quick turn around time of PVA. The downside is that bleed through is a serious problem and creep can be a problem as well, PVA is not very good for bent laminations because of the creep.
3.) Plastic Resin, it comes in a powder and is cheap and rigid.
4.)Epoxy, great stuff if you don't get bleed through but it is pricey.
7,468.) Contact cement, Wow, I'm surprised it made my list at all! Well, 7,469 is roofing tar.
Lee
Furniture Carver
