My first big project; perhaps too ambitious, but I want to try it. I purchased plans for a Morris chair from FWW. The instructions tell me to use 1/8 inch veneer around a core for the front and back legs. That means a miter joint longways on each of the sides of the veneer? That’s how I picture it, but how do I cut a miter joint that will match all the way up and down a twenty some inch leg on 1/8 inch material? I believe I can cut the veneer; it may end up a little more than 1/8, I can make up for the width by changing the dimmension of the core. It will be as close to 1/8 as I can make it. I have a bandsaw, jointer and planer.
I have a similar question to the above regarding quartersawn oak. In my area the local dealer doesn't maintain a stock of quartersawn oak larger than 15/16" rough sawn. My plans call for starting with 6/4 and 5/4 rough sawn to end up with final dimensions of 1 3/8" and 1". Is it better to try to veneer the 3/4" up to the final dimension while keeping the ray fleck on the surface, or will I be ahead of the game by just ordering the right size stock from the start?
