I have a small antique veneer covered table with many cracks in the top surface. The cracks range in size from about 3/32″ to 1 1/4″ long across the entire surface. On other simular projects I have used a piece of paper with yellow glue and tried to push glue under the raised crack. With so many cracks I would like to use a syringe and an adhesive. Yellow glue is to thick. What glue should be used or is there a better method that I should try?
Hot hide glue.
F.
