Hi,
I plan to decorate a beech picture frame with initials of contrasting veneer. The production of accurate veneer letters is no problem (coping saw), marking the frame surface with a sharp Japanese knife (one side flat) should not be impossible.
BUT: How do I chisel/scrape/scratch/drill the flat bed for the veneer letters into the hard wood surface? The letters are simple Arial Bold with mostly straight and one curved contour. The width of the letter arms is appr. 1/8in. Are there any leprechaun-sized chisels built for human-sized hands?
Fritz
Fritz, you probably won't go wrong with these,http://www.leevalley.com/wood/page.aspx?c=2&p=31104&cat=1,130,43332,43333&ap=1
I am the worlds worst carver but find that I like the long handle over the palm but carvers like those shorties. Good luck, Paddy
Hi Paddy,Thank you very much - this is exactly what I was looking for! I've placed an order and I am now with some trepidation for their quote on p&p (probably as much as the chisel set again).Fritz
http://www.leevalley.com/wood/page.aspx?c=3&p=52609&cat=51&ap=1
Buy or make something like this. There are also very small and affordable versions of this tool.
Don
More appropriate than the Veritas Large router plane would be the new Veritas Small Router Plane. While the plane comes with a 1/4" blade as standard, I made myself two more, a 1/8" and a 3/16" out of hex wrenches/Allen keys. These work very well.
I have just (!) completed a review of this plane. It is available here:
http://www.onlinetoolreviews.com/reviews/veritassmallrouterplane.htm
(no affliation with the website - just asked to write a review).
Hi DonC,I'm afraid, this fine tool - even after some ingenious modifications - is still to large to cut intricate paths as the ones I am trying to deal with. I could possibly do some straight grooves, but corners and curves would still require filigrane carving.
But, thanks for helping me!Fritz
Flexcut's small chip carving knife may be useful to you too.
Three tools available to do this easily:
In all cases, incise your lines down to depth first.
regards,
dave
