Hi- Quick question regarding veneering. In the recent FWW Q&A, (226), it is stated that if veneering a curved drawer front, one should glue up the plies of the substrate before appling the face veneers. Michael Fortune, in FWW 210, said something similar about veneering curved doors. Make the curved substrate first, then apply face veneers. My question is why? Is it not faster to do it all at once? What are the disadvantages of doing so? Thank you,
Michael
I haven't actually done this but
I am thinking spring back. Make up the core, let it spring, cut it to spec then can veneer it with out change.
One could then better control how the veneer relates/aligns at the joints.
It will be interesting to hear from the people who work this way.
When working with curved panels in general the panels are usually laminated oversize.
Once trimmed to size a solid edging can be applied and/or more care can be taken to apply the face veneer without the hassle of manipulating multiple pieces of core material and veneer at the same time.
Cheers, Don
"The solid edging"= of
"The solid edging"= of course! I had forgotten about that. A real "Duh!" moment. Thanks.
Veneering
If you can do it all at once - it's fine - just a different technique. When I visited the Steinway factory in Queens, NY - they were doing a case bending. Industrial equipment...... but they bent the case with 9 laminations and the finished veneer - all at one time.
SA
Steinway Factory
For those who would like to see them make up the piano case that Westchester refers to see your NetFlix. They have it on instant view right now. See the documentary called
Note by Note: The Making of Steinway L1037
It is also available on Amazon as a DVD or if you have "Prime" then it is free to watch on instant view there.
http://www.amazon.com/Note-The-Making-Steinway-L1037/dp/B001P8M9FK/ref=sr_1_1?ie=UTF8&qid=1333762504&sr=8-1
I highly recommend this documentary.
