Can I build a ventilation system for furniture finishing? I am a hobbiest and have just built a small work shop over my garage. I’ve looked at spray booths online and they are either huge for professional use or too small (i.e. for model builders).
HI,
Just made a cheap portable booth. Bought plastic that comes in 8 foot by 100 feet rolls. Clamped it to floor joists in shop ceiling, and cut hole for my air cleaner. Worked great for $10 total. Was only spraying water based poly.
Fww had a article on a knockdown booth by Jeff Jewitt. He says keep it simple and spend your money on a good fan.
You should be able to find it if you scan the fww index.
If i can help, let me know.
Stevo
Thanks Stevo....I was thinking about using plastic sheeting to prevent overspray in the rest of the shop (which is being used for my many interests). I was wondering about venting it outside -- and trying to figure out how elaborate of a system I need.
