Any reviews on the Veritas honing guide for plane irons
and chisels?
Kevin
Hi Kevin,
I have used the Veritas honing guide for a couple years now with good results. I use water stones and find the guide makes it easy to get the job done quickly and accurately. In addition it's got an offset to put a secondary bevel of 1 or 2 degrees. The set I got included an angle guide which makes it easy to set angles of 15, 20, 25, 30 or 35 degrees. I just make sure to lubricate the roller after use due to the water. I'd say it's a good bang for the buck.
Be safe,
Ken
Kevin
I have one, and love it.
Ben
I bought one a year ago. I use it to sharpen chisels and plane irons on sandpaper and plate glass. The edges always turn out razor sharp.
The jig makes it easy even for a first timer.
I highly reccomend it!
Hi and thank you for info. Just posted a message re help for sandpaper based sharpening and need a little help as to adhesive used to adhere to glass Have not heard of the jig in Australia.
K K
Yep!
Regards...
sarge..jt
I use one. It seems extremely fiddly to adjust so the edge is exactly square to the sides, but it's still miles ahead of anything else I've tried. I keep trying to invent a replacement with the clamp independent of the angle adjustment, but I'm not making much progress.
Thanks everyone. I purchased one today.
Kevin
its kinda lame for small chisels (hard to get square) but larger chisels and plane blades work well.
Since you have already purchased it, this may be late. I found the guide to be very good, particularly when I first began sharpening chisels and plane blades. Then I bought some Japanese chisels that had short blades and the guide was worthless. Then I built a jig with which to sharpen the shorter chisels without the guide. Then I asked a few experienced guys and learned they didn't use any guide or jig at all but did it all by hand; my reaction was it couldn't possibly be as good as using a guide. Then I found (through this forum, I think) a piece on sharpening by hand, used it, and now today, I sharpen everything by hand. (Sorry, can't find the piece on sharpening by hand.)
I think there is a progression one goes through( and maybe that is good) but sooner or later you may find you sharpen without a guide. If you are just getting started the guide is great and if you never get short blades (such as Japanese chisels) the guide can continue to be a great way to sharpen.
Sailalex,
This kind of discussion goes on and on. To each his own.
I learned to hone by hand. I did it that way for many years with excellent results.
I now use a guide, and recommend a guide over free-hand as superior for maintaining an accurate honing angle.
I prefer the Eclipse (also referred to as a "vise-type") model.
VL
This is an article I found and it gives an outstanding "How To" on hand honing (which unless you damage your chisel/iron is all you need to do).
http://www.antiquetools.com/sharp/index.html
Enjoy.
Joel
