How thick a piece of softwood/hardwood can I reasonably be expected to be able to use this plane with? On hardwoods (very dense Australian hardwoods) I’m stuck at a maximum of 5/8 thick and on a soft pine at 3/4.
The blade is at 35 degrees, anything less on the hardwoods and it the edge doesn’t last.
I’ve tried lubricating and its not making much difference.
I'm assuming your current limitation is due to the plane being used(?). The 2-1/4" blade on the Veritas is seated off axis to the plane body so you lose a little of that measurement there. The shooting board's construction can also cost you some blade height.
I use their plane and their shooting track and have planed 8/4 material that has been milled down. I would guess a fat 1-3/4" pretty confidently. That being said that is getting to be some pretty stout stuff to be shooting. Maybe that is just my experience(?).
Yeah, taking a full width shaving off 1-3/4 end grain takes a really sharp blade and some elbow grease.
What blade angle and species are you using to get through 1 3/4"?
@boxbrush - A 30 degree primary with a degree or two of micro bevel on walnut. This is already milled material that just needs the end lightly brought into square. That is, the capacity allows a full height cut but I am only cutting whispers of those areas out of plane. I don't have the guns to plane 1-3/4" of end grain as a roughing step ;-))
My Veritas Shooting Plane uses a 25 degree bevel, and the edge holds up very well in Australian hardwoods. I suspect that your bevel angle is too high and edge not sharp enough.
See my review of this plane: http://www.inthewoodshop.com/ToolReviews/LVShootingPlane.html
