I’m getting to cut some raised panels in cherry with a vertical router bit (using a router table with a high fence). The panels are about 6″ by 24″.
I’ve seen in other threads (one from PlaneWood) that some use a jig of some sort to guide the pieces. Can someone post a photo or description of the jig please? I plan to make at least three passes to the final depth.
With this type of bit, should I run the end grain first or second?
I’m using a 3hp variable speed router, any suggestions on the speed? The deepest part of the cut is only about 3/8″?
And finally, can someone tell why its 10 degrees and snowing in the Northeast and its not even winter yet? Brrrrrrrrrr
Thanks all,
Norse
As to the jig..... I would certainly use enough featherboards to assure that the workpiece could only move in the intended direction. And with a vertical setup, that won't be as simple as it would if horizontal. You'll probably need featherboard (or jig) "coverage" for the entire height of the bit.
I'd do the end grain first, with a fast bit speed, and a slow wood speed.
And sorry to hear of your weather misfortunes. It's cold here in Carolina too. Almost got down to 35 last night. My son is in Providence, and I feel for both of you. But that is one of the reasons that I moved out of the snow belt.
Just in case you are interested...
I made a fine router table from one of the ww mags (can't remember which) that includes a setup at one side to hold the router horizontally so that you could use those bits and hold piece flat on the table. Works well and feels safe.
let me know if your interested and I'll send the mag info and/or a pic.
That sounds very interesting, it would be great if you could post a photo or the info.
Norse
Sorry it took so long, the Holidays got crazy. Here are the pictures of the router table, couldn't find the mag...
Let me know if your interested and I could provide some additional details about the table.
Jeffrey
Thanks Jeff, it looks like a great table. The piece I was making, a cherry mantle, had to be in place for the holidays so Santa could find the stockings so I bulled ahead and they came out fine. It was a vertical type bit and I have a 8" high fence on the router table so it was really easier than I thought it would be. I experimented with cutting the end or long grain first and found it made no difference at all with a slow feed speed. I also have an adjustable opening on the fence and kept it tight on the bit which I think also makes a difference.
Anyway, thanks again,
Happy New Year!
Norse
Jeff -
I will add that to do a curved top panel door you can simply add a matching curved guide to the table. Temporarily tack it down with a brad nailer or screws.
Neat looking table you got!
