Just bought a Craftsman Cabinetmaker’s tablesaw, assembled it, turned it on–et voila, the motor vibrates (subsequently the whole saw)–not a lot. How does one reduce vibration?
If it's the standard arrangement of the belt being held in tension by the weight of the motor, it's normal for the motor to bounce a wee bit. But it shouldn't shake the saw. You may have something unbalanced, out of adjustment, or loose.
Some things to check:
If this doesn't help, try posting on Knots. There are a lot more people who read postings there.
Even after you have everything else setup perfectly, get a Link Belt.
http://www.rockler.com/ecom7/product_details.cfm?sku=6040&filter=link%20belt
I had a Craftsman contractors saw that worked fine, but had a vibration even after the belt had warmed a bit from running. Replacing the original belt with a link belt made startup and running as smoothe as silk. I even tried the test of placing a nickle on the saw table before and after replacing the belt. No way it would stay still under any circumstances with the original belt. With the link belt in place, the nickle didn't move even when first starting the saw.
Bill Arnold
B&B Woodworking
That did it!
Thanks!
k
A year or two ago I kind of 'inherited' a 10" Craftsman contractor saw. Ran fine, other than vibrating all over the place. It had lot of other problems, such as bolts loose or busted off connecting the top to the cabinet, the cabinet housing was damaged and not structurally sound, etc. (the saw had been badly abused by previous users). Once I had all *that* fixed, it still vibrated a lot. A little less than before, but not much. I put on a Link-Belt like one fellow here already mentioned, and it helped some more. What really did the trick though, was to get some machined pulleys. The stock pulleys are cast iron w/ little to no truing performed, so the holes aren't always centered. The machine pulleys run much truer w/ very little vibration. You can probably find a set to fit your saw at someplace like WoodCraft.
HTH,
Monte
"V"
Change the name on the saw from "craftsman" to almost anything else
Welcome to the
Taunton University of Knowledge FHB Campus at Breaktime.
where ...
Excellence is its own reward!
