I am building a sofa table of walnut.I want to finnish it natural but want to fill the open grain. The top is plywood banded in solid wood.
sounds ok--did you have a question?
*My question is,what would be the best way to do this?
*after sanding, apply a dark brown paste wood filler (follow the directions on the can), and let it dry thoroughly for several days. over that you can apply watco or any other similar oil/varnish mixture--a couple of coats will do.
*I saw an article or something in a book on getting a smooth clear finish on an oak table (which is also open-grained).Flood on polyurethane and spread it with a squeegee. This fills the pores. Do as many coats as it takes.
*I AM DOING AN ENTERTAINMENT CENTER IN WALNUT. I HAVE NEVER FINISHED WALNUT BEFORE, AND AM GETTING A LOT OF CONFLICTING INFO. I LIKE SOME RED IN THE WOOD, DEWAXED GARNET SHELLAC WAS MY FIRST CHOICE AS A SEALER COAT THEN VARNISH OVER TOP AS A FINISH. THE SHELLAC DOES NOT GIVE ME TH RIGHT COLOR, SO THEN I WAS GOING TO TURN TO TONING.........EXCEPT I HAVE BEEN TOLD THAT THE WALNUT WILL TURN RED OVER THE SPACE OF 4-5 YEARS. IF IT DOES THEN I WILL HAVE OVER COMPENSATED FOR COLOR AND HAVE A BLACK PIECE.------HELP!!
*CJ: Why fill the walnut? I've made a set of living room tables (two end and a coffee table) and a drop-front desk, all of walnut. No filler on any of them. The only time I used filler, which was on ash many years ago, is the only time I'm going to use it. I used semi-gloss poly on all the pieces and they turned out great. I found applying with a bristled brush to be FAR superior than a sponge brush. I'll never use those again, either.Regards from NM. Dale
