O.K. all you pros. jump in here and help me. I am fairly new to this wooworking business and need to know about sanding walnut. I’ve built some small clocks and the more I sand the walnut the more sanding dust gets in the grain[I guess] I’ve got the surface as smooth as glass but there seems to be a chalkie[white] film on the wood that I can’t seem to get off.Does this always happen with dark wood such as walnut?What do I do to get the white film off, or can I go ahead and put my finish on? I am going to put on a clear poly. satin on it. Any and all help will be appreciated. Thanks,Bob
Bob,
I really don't know about this film of which you speak, it may be dust. Blow or vaccum the dust before you apply finish and sand between coats. Don't waste your time sanding past 180 or 220 for a film finish. For stain I'll go to 220 but for clear finishes I frequently don't sand past 150. The first coat will be as rough as a cobb so plan on the sanding between coats.
Lee
For sure, you don't want to finish it until you get the surface clean. Just in case, what type of sandpaper are you using?? Brand and stearated or not?
forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
take a damp cloth and wipe it off.. you'll want to raise the grain a little anyway especially if you are using water based finishes..
That's why I use hanplanes and scrapers over sanding...especially when using darker woods like walnut. It's not too late, give it a try and it should get rid of all the dust stuck in the wood pores.
Eric
Bob,
If it is indeed wood dust you could use an oil finish or a 3 part (oil, poly, mineral spirits) finish and the dust would act to fill the pores slightly.
Try moistening it with mineral spirits. If it is sanding dust, it will darken just as the wood itself does. If it stays light, sorry, I don't have an answer.
Apparently you are looking for a very smooth finish. Walnut grain is open enough that it needs to be filled if you want that "mirror smooth" look. One way is with a dark wood filler. Another way is fine sanding with the first oil/varnish (poly) coat, so the sanding dust becomes a filler glued in by the oil/varnish. Or a variety of other techniques to fill the pores.
________________________
Charlie Plesums Austin, Texas
http://www.plesums.com/wood
Wipe it down with naptha. Won't raise the grain. Evaporates quickly and will take most anything off....
