I’m starting a chest that has onion bun feet legs to be turned on the lathe and I’m wondering if it would be ok to use walnut? The plans call for mahogany which I’m trying to stay away from. Any ideas?
sdlreese
sdlreese
IMHO walnut is a wonderful wood to work with. If it wasn't for the drak color, I'd use it more.
sdlreese,
I much prefer mahogany over walnut because I grew up believing it was a superior wood in furniture. About 15 years ago I read that English craftsman, back in the whenever, were forced to switch to mahogany because walnut from Europe was no longer available. Two years ago I built my first walnut piece and was extremely impressed with its workability and finish.
Walnut would be an very appropriate substitute. The grain structure is somewhat similiar
and you will find the walnut considerably harder than the mahogany. The Walnut of course
is darker so don't make the mistake of thinking that you have to use a dark stain. I have created some interesting color on walnut by starting with an amber color dye for a base color
and over wiping that with a fruitwood color. This makes the grain look a bit more active than
if you were to just put a walnut stain on walnut. My experience with walnut is that the material that comes from the northeast can be a little bland grain wise, the material we have
from around the southeast tends to have more contrast and activity in the grain.
Ron
Except for grain patterns in wide boards, walnut has more of the characteristics of the traditional Dominican or Cuban mahogany than does Honduran mohogany; it is heavier, denser and harder like the old stuff. Few of use have seen Dominican mohagany. Friends just bought some 18th C English side chairs made from the stuff and man are they heavy. In contrast, currently available stuff is much lighter. I can make walnut look very much like mahogany. The key is to bleach with two-part bleach which makes the wood a pale grayish-brown. Then stain with a water-based analine dye; a brownish mahogany should work but experiment with the redder shades too. Top with shellac and wax and you'll be all set. Rick
I work almost exclusively in walnut because I love it's stability, workability, beauty and the way it takes my favorite finish (oil/poly).
One of the great things about turning walnut is the fragrance emitted as the chips fly.
Some walnut has difficult grain so be sure your roughing and spindle gouges, skew chisel etc are sharp.
Do wear a good mask when you lathe sand because walnut dust is wicked on the respiratory system.
