im kind of new to wood working I built a 8 foot black walnut mantel for a stone fire place that also has 2 side wings. it is 11.5″ wide 8′ long. I would like some advice on a nice finish to use to bring out the depth of the wood and add a bit of warmth . I have the time to do most any type of finish im retired. Also i can use any method to apply from wipe brush or spray I have a 4 stage turbine. So any help would be much appreciated. thank you steve
Steve,
Black walnut has a great inherent color and finishes very nicely.
One consideration would be to use a wipe on varnish such as Waterlox which is easy to apply and will lend a little warmth. It is a very close to the grain finish which means it won't build up a film thickness but give a "natural " look and still provide some protection.
You might also consider doing a light application of a very thin varnish such as Watco or Minwax Oil to "bring out the grain" Let it dry for a few days and you could then spray it with nitrocellulose lacquer.
Another consideration would be a brushing varnish such as McCloskeys or any of the other brands.
They will build a very nice coating in as little as three coats. Of course it is slow drying so be sure and keep the dust down.
Do yourself a favor and read some of the books on finishing. You can find them at most good libraries and will help bridge the learning curve.
Also be sure and make some good size samples. These will also shorten the learning curve.
Since you're retired (congratulations!) you should have the time to enjoy yourself doing it.
Be sure you prepare the surface well. A sanding to 180 grit should do it.
Good luck.
Peter
