Yesterday I bought some walnut oil for a cutting board that needed some help. A fellow woodworker friend recommends it as the best food safe finish. While doing the board, I figured I’d use the same walnut oil on some little knick knacks I’d made for Christmas — which are walnut coincidentally.
I found a distinct pleasure in caressing the oil into the wood with my bare hands — something I would certainly never do with my usual oil-varnish-mineral spirts wipe on finish. It seems like the perfect way to complete a piece.
I’m wondering whether walnut oil would make a good finish for furniture. How well will it protect wood relative to other oil finishes — linseed, tung, danish, etc.? Will it build up with successive coats like these other oils?
Like linseed oil, walnut oil will eventually polymerize into a stable finish but this takes months to accomplish and it may not be practical for applications other than on a cutting board where a little oil seeping out of the wood occasionally will do no harm.
If you want to use a safe and pleasant to work with oil, that will harden more quickly and build up a finish, try using the boiled linseed oil from "Tried and True". Their oil is pure linseed oil with no additives, but it has been heat treated to accelerate the hardening. Pure linseed oil is edible and is called flax seed oil in health food stores, but again the food store version is untreated and very slow to harden.
John W.
Thanks JohnW,
I actually have a can of Tried and True that I've yet to open -- waiting for a big project that will consume most of it.
I wonder whether walnut oil can be heated like pure linseed oil in order to help with polymerization. I've learned that most vegetable oils will tend to polymerize more readily under the influence of heat -- it happens to be the achilles heal of trying to burn straight vegetable oil in diesel engines.
I guess I like the idea of running down to my local health food store to buy my finish rather than having to mail order or make a trip to the big city.
Maybe I'll conduct an experiment. Any suggestions as to how long and at what temperature to heat the oil?
Thumb:Walnut oil has a flash point of >300°F, boils at 500°Fhttp://libertynatural.com/msd/127.htmIf you elect to try it, I'd use a double boiler to do it, outside, well away from buildings and trees.Note that it goes BOOM before it boils.Note also comments about allergens. I doubt that heating it will alter these factors.Regards,Leon Jester, Roanoke VA
thumbsmasher,
Why would you not use your hands with the oil-varnish-mineral spirits ?? I do it with my Waterlox...apply a nice thin coat and rub it in well. Is it really something I should not be doing?
Read the warnings on the can. I used to get linseed oil and mineral spirits all over my hands, but I eventually realized that this was not a good practice, so I started wearing disposable gloves. It's advisable to avoid direct skin contact with petroleum solvents and the heavy metals in "boiled" linseed oil and varnish since they can be absorbed through the skin. If you work with this stuff regularly, it's best to minimize long-term exposure.
I've used walnut oil on cutting boards in the past. Walnut oil is one of the few vegtable oils that won't turn rancid. However, I always wondered weather walnut oil would affect people with nut allergies. Last summer, I met a lady who has had nut allergies since she was a child and she assured me that, yes, she would have a severe reaction to walnut oil on a cutting board. It's a serious problem for her and she carries a vial with some sort of anti-toxin whereever she goes.
Chip
Thumb, evidently you missed the following discussion on finishing cutting boards vis a vis serious tree nut allergy problems:
http://forums.taunton.com/tp-knots/messages?msg=20474.12
It was imbedded in a thread about wood choices for cutting boards.
Please consider finishing all of your cutting boards and wooden utensils with mineral oil.
