Hi there-
One of the things I’m not set up for is doing veneer, and I’d like to do a couple veneered panels for doors on a case I’m making for my wife. Having never done veneer, I’m not sure I could hammer-veneer a panel this size, and am just not quite ready to buy a press.
Anyone interested in glueing one up for me real quick?
I need 2 panels, 12″ x 22″, preferably on 3/8″ MDF with plain walnut on the back and a walnut burl on the front. You don’t have to: sand or scrape it, apply a finish, or do anything at all to the edges. 12″ x 22″ will give me room to clean it up. I can go get the veneer and MDF even if you’d like.
If you’re in or around Houston, TX that would be handy too… Anyone interested in helping a fellow woodworker?
Thanks a bunch,
Kevin
Kevin,
If a drive to Austin with a few hours to kill isn't too much for you, I do have a veneer press and wouldn't mind pressing your panels for you. I don't presently have any walnut veneer, but I do have a huge supply of quilted maple......drop me a direct email if you want to discuss further.
Don
kevin, click on my website linked below. Slainte.
Website
The poster formerly known as Sgian Dubh
Kevin,
You don't need to buy or make a press, or even buy or make a vacuum press. Buy a couple of books on the subject. The method I like best is the iron-on dry PVA glue method. Basically it involves coating both the substrate and the back of your veneer with PVA gluve (white or yellow). Let it try for a day or two. Position your piece of veneer on the substrate and iron it on. The heat reactivates the PVA glue and you have "instant" adhesion at a rate that YOU control rather than hide glue controlling you.
Scott
I'm not an expert on working with veneer, but i've done some work with them, and they've turned out pretty well.
The way i do pannel of veneer is to glue the veneer to the substrate (mdf, pine, or whatnot) and then sandwich it between two pannels and then clamp it tight.
It should look kinda like this...
Hey all!
Another great way of laying up a veneered panel without spending alot of money is to use contact cement. I have found that a can of "spray 90", made by 3m , covers about an 8'x8' area when evenly sprayed. Your panels would only need one can witch runs about 8$ or so. A simple hand roller will be all you need to create a good adhesion of your panel and veneer. Make sure you do both sides as quick as possible to prevent any draw.
I Use paper back veneer which can be ordered and shipped easily from many suppliers. It can be cut very easy and has very little movement once its glued and finished. It is thin so watch how you handle it.
God speed!
Boy, protagora, I've never even veneered anything and I already know you've opened up a whole can of worms here with the contact cement thing... I've seen a ton of very firm opinions against it, but keep in mind I've certainly never done it myself. Have you used it on big pieces or just small?
Looks like Richard Jones will be kind and generous enough to let me occupy a corner of his shop for a couple hours once my veneer arrives from Flamingo. Can't wait.
Thanks to everyone who posted though. Perhaps after this first try, a vacuum press will be in my near future!
Kevin
these aren't large panels, and they are flat... seems like sandwiching between mdf and clamping generously with cauls would do the trick.
