I just completed a book shelf/cabinet unit and as I was installing the doors and I came across 1 door that had a warp to it, these are raised panel doors made out of poplar wood . these are inset doors. the warp is about 1/4 inch. can anyone help me and give me some direction on what I can do to bring it back flat. thanks . also this is my first attempt at using this web messaging. I have no clue how I get the answer from this question. the door size is 20in. x 18 x 3/4.
Edited 1/22/2007 8:50 pm ET by jackmack
Edited 1/23/2007 7:43 am ET by jackmack
Hi Jackmack,
I hate to be the bearer of bad news, but I think your only option here is to make a new door. Even if you are able to coax it back to flat it will likely move again.
You should be able to salvage the panel so it's just a matter of milling up new stiles and rails and reassembling them.
I have a question for you: Did you joint and plane the lumber for the stiles and rails, or did you use pre-milled lumber? If you jointed and planed, then I suspect the wood wasn't completely dry when you milled it. If you used pre-milled lumber, than most likely you started out with a warp and it carried over to the final assembly. Another cause for the warp could have been due to the joinery; possibly one of the corners didn't go together square.
If you're dead set against building a new door you can plane the door flat by wedging the high corners and removing the high points with a hand plane. But that is going to cause a number of problems, including creating a thinner door than the rest, and creating an inconsistent thickness.
Matt Berger
Fine Woodworking
thanks for the info. Thats what I did, salvaged the panel and made new stiles and rails. It was off the shelf poplar from a local lumber yard. thanks again for your advice. jackmack
Edited 1/24/2007 8:49 pm ET by jackmack
Glad to hear it worked out. Do be leary of using premilled lumber without jointing and planing. Unless the mill did a really good job, most likely this lumber will not be perfectly flat or square.
