I AM MAKING PANELED DOORS FOR A CABINET. ONE OF THE DOORS AFTER HAVING ASSEMBLED IT IS WARPED BECAUSE THE OF THE PLYWOOD PANEL IS THERE ANY WAY I CAN SALVAGE THE DOOR WITHOUT MAKING ANOTHER. THERE IS DEFINITELY A TWIST IN THE DOOR I TRIED WEIGHTS ON ONE CORNER BUT IT HASEN’T WORKED AS YET.
I WOULD APPRECIATE ANY HELP THAT I CAN GET
RALPH
Assuming the doors have solid wood frames you can try flattening the door with a handplane. If that does not work for you I would guess you need to make a new door. Maybe someone else has some ideas??
good luck
Bob Van Dyke
Thanks Bob
I think I'll take your advice and make a new door. Thats's seem to be the best way out of this problem. Thanks for taking the time to reply.
Regards
Ralph
