hi all…
gibby macmaster saying hello for the first time. i have a question: have joined 4/4 s4s walnut together for bathroom vanity decking for a remodel. unfortunately, the decking was placed in an outdoor humid area and presently has a slight but even concavity (convexity?) is there some way i can moisten one side of the wood, clamp it with clews, and hopefully straighten the boards?
Thanks!
Possibly, But not likely to get it totally back to dead flat. Try drying convex side up, It might straighten out on it's own when the lumber reaches equilibrium. Or lightly dampen the convex side and let it dry with that face up.
Bruce S.
Edited 6/21/2006 6:01 pm ET by BruceS
Edited 6/21/2006 6:03 pm ET by BruceS
"Or lightly dampen the convex side and let it dry with that face up." Unfortunately, Bruce got this part backwards.
I've straightened (uncupped) several small table tops and other boards using the "dampen and re-dry" technique. You do not need clamps! They don't help. Here's how it works....
The concave side of the board has dried more than the convex side. So, what you need to do is raise the moisture level of the concave side, lower the moisture level of the convex side in comparison, get it to dry flat, and get a protective finish on it ASAP.
In your situation, you may simply need to flip the assembly over and let the concave side absorb some moisture until the whole thing is flat. Then sticker it up in your workshop, let it dry evenly and get a moisture barrier on it, or at least don't put it down in the same moist area it was in before.
With an older piece of wood, what you do is lay the wood, concave side down, out on the grass with a layer of newsprint underneath until it flattens (in not-too-hot sun). These conditions can be duplicated by using a damp towel and a chicken-hatching light. Anything that raises the humidity on one side and lowers it on the other. Then, once it dries, if it re-cups you do it over again, but bring the board slightly past dead flat (e.g., cupped on the other side) and then let it dry again.
It's really important when you let it dry that it be stickered up to get air ciruclation all the way around the two faces.
PS: Welcome!
Edited 6/22/2006 7:52 pm by forestgirl
dear forest girl..
so many thanks for your time and effort posting the technique to correct my warped wood. my troubles are the simple definitions of concave and convex, cyma recta, reversa, etc... perhaps it's a dyslexia thing? probably just lazy brain syndrome!
your input is most appreciated and will be followed!
bruce
Forestgirl, My slip, What you said is what I meant to say. And I knew better.Work Safe, Count to 10 when your done for the day !!
Bruce S.
"And I knew better." As well you should! ROFL!! <dig, dig>forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Good question.. I just did that with some reaction ASH... Geee.. I had one board about 18 inches wide.. Now it is strips of about 4 inches wide glued together... ALMOST flat! and ALOT thinner than it was at the beginning!
Edit: Wood is like a woman.. You see beautiful and ya' but up with the faults!!
Edited 6/22/2006 4:03 pm by WillGeorge
Use the 6-pack method. On a nice, sunny day, water the lawn first thing in the morning. After the day warms up and the sun comes out, place the offending piece of wood on the lawn so the concave/hollow side is down. Open first beer. Drink at a leisurly pace. Check board. Repeat as needed.
Mike Hennessy
Pittsburgh, PA
well spoken mike! thanks!
