Hi,
I have a question regarding finishes. If I want to highlight the natural colour and figure of the wood What finish should I choose? I’m working with lodgepole pine. I was thinking about applying a clear water based finish although it’s not as durable as Polyurethane varnish . Would spraying on the finish create a much smoother finish than brushing it on? The term “rubbing it out” I take it that means lightly going over the last coat of dry finish with a lubricant (mineral oil, mineral spirits) and 400 grit or 600 grit sand paper. Then applying a furniture paste(wax) and buffing.
Wanda
A water-based finish will not give quite the "depth" as a more traditional finish would. You might want to try a gel varnish such as Bartley's.
Rubbing out is a procedure to smooth the finish and provide the exact degree of luster that you're looking for. Here's Jeff Jewitt's on-line article on rubbing out:
http://www.homesteadfinishing.com/htdocs/rubbingout.htm
Take a look at this page for color samples of woods finished with Bartley's gel varnish and gel stains:
http://www.homesteadfinishing.com/htdocs/Bartleystains.htm
with a good w/b finish you should be able to go over a oil base stain as long as you give it enough time to thouroghly dry. It also should not have silicon in it . So the type of stain for your need ...i would suggest a o/b
Darkworksite4: Subterráneo en la república de gente de Calif
Wanda,
There is a few ways to accomplishes this using water based finishes.
Fuhr 255 is the best water based finishes I've used to date. It drys very much like a solvent based urethane, sands well and after it fully cures (about 7 days) is super hard, durable and chemical and water resistant. It's hard to beat.
