I am using my standard oil/varnish formula (1/3 linseed oil, 1/3 mineral spirits and 1/3 varnish) on a large hard maple bed. I would like to put a finish coat of gloss water based poly over it. Is there a minimum amount of time I should let the oil/varnish finish cure and do I need to sand it at all first?
thanks!
I do this all the time with Watco. I usually let it dry for 72 hours (3 days) or until I can't smell it anymore. then coat with water based poly.
TDF
Are you sure I don't need to seal it first with a coat of de-waxed shellac??
depends..enduro a waterbase product I use says its ok as long as they o/b doesnt have silicon in it. I definately make sure it is good and dry before top coating it. depending of the product I waited as much as 4 days to finish.
Take a piece or two of scrap and apply the o/b and use it as a test piece before finishing your project.
Caution: This message may contain "For Official Use Only" (FOUO) or other "sensitive information" is not intended for non-official disclosure. Do not disseminate this message, except to persons who require it for official Breaktime purposes, without the approval of the individual originating this message or other authorized official of the Taunton University. If you received this message in error, please delete it.
okay, thanks!!!!
As long as the oil/varnish is fully dry, it can be overcoated with a waterborne varnish.Howie.........
