Hey fellow woodworkers!
I’m thinking about making this table out of 25 mm white oak. Not as wide as the pictures. Thinking 60x40x30 cm.
Does anyone have input on what type of joint would be the least fragile?
My spontaneous thoughts are wide fully blind mitered dovetails. Do you think I would need some kind of bracing on the underside connecting the “legs” and supporting the top board or would it suffice without?
I’m doing it with hand tools only. A bit new to woodworking, maybe I’m out on deep waters here, but I really like the aesthetics of this table.
Would love to hear your input
A fully blind dovetail would certainly work but as far as being strong enough by itself, is difficult if not impossible to say. If it's going to be subjected to daily use, I would say it should have some type of bracing no matter what joint you use.
Thanks for the reply.
I have a hard time figuring out how to place the bracing. Would it be best to have a vertical thinner board going across from each leg attached on either side in a sliding dovetail. Thinking the leg boards are too thin to do a mortise for a rail with tenons on each side.
If that makes any sense?
Here’s how it’s been done before with thicker material. I would plan on incorporating some sort of support / bracing in your design.
Being new, consider building a smaller scale test table out of scrap wood to dial in your joinery & design. Enjoy the journey!
Thanks for the tips! How would you insert the bracing? Can’t really tell from the picture…
The bracing is your aesthetic choice. You can chop out shallow mortises in the sides and top and glue in (consider epoxy) an oak brace with end tenons. Another option is to screw in metal right angle “shelf” supports from a big box store or a specialty retailer. If either are small enough, they might not show enough to detract from the design.
Just saw this on youtube. Wonder if that would do anything for support. Looks like a loose tenon with an angle brace. Haven’t seen that before. Looks neat. By ”The Periodic Studio”
https://www.finewoodworking.com/2018/03/14/rock-solid-miters-l-tenons
And
https://www.finewoodworking.com/2016/03/30/add-muscle-to-your-miters
And
https://www.finewoodworking.com/2013/10/03/strong-and-handsome-half-blind-mitered-dovetails
And
https://www.finewoodworking.com/project-guides/chairs-benches-and-stools/basic-chair-at-first-glance
There's more... I put " braced miter joint " in the search box at the top of the page.
