The label on the waterlox original does not mention to wipe off
the application that is applied. This is my first time using it so I’ll
do some sampling but wondering what someone out there might
know. Seems like the other oil, oil/varnish products out there always
get wiped off. Thanks very Much.
The reason Waterlox (I assume Original/Sealer is the one you mean) doesn't say you need to wipe off is that it is not an oil/varnish mix, it is varnish, albeit one thinned enough for wipe on application. It may be allowed to build a film on the surface. That said, it generally works well wiping it on in a number of very thin coats that leaves the surface damp not "runny." I you apply 5 or 6 coats you will have a film about the same as 2 thin coats of brushed on full strength varnish, providing an attractive finish that is much more protective than one achieved with oil or oil/varnish mix.
Waterlox can be brushed, but if you are going to apply and even out varnish by brush you might as well use a full strength varnish and complete the job in half the number of coats.
I've just started using Waterlox Original. Even though it's extra coats, I like the ability to control the gloss and keep the finish thin. I've been applying the first coat by applying liberally until no more is absorbed, then wiping off the excess, just like you do with oil. I wipe on a second coat (sanding between coats), then brush on a thin third coat. The result is a thin coat with just a bit of sheen.
I'm a big fan of Waterlox.
As stated, you don't need to wipe off. I apply with cotton rags. You may already know that these rags can later self-ignite unless thrown away without oxygen or wet. I throw the rags into plastic bags then add water and tie before I throw them out.
Another problem is that it gels quickly in the can. Keep the cap real tight. Otherwise, I like Waterlox.
I used Waterlox on my workbench tops and down in the tooltray where there's a lot of things moving in and out...
Using Maple, White Oak's heartwood, and Black Walnut, I wiped on the finish with a T-shirt material pad and followed their directions. I flooded any areas of the open grain woods that soaked in, evened out the coat, and let it dry.
I still need one more coat to completely finish up, but look at the difference that first coat made....
Bill
