Greetings!
I’m working up the designs for a number (8 or 9) segmentally turned flower vases. The construction and lathe turning is not a problem as I have already been trough a number of “experiments”.
My question is this: Given the multiple polyurethane glue joints (short spans of wood) of segmental turnings, would a common polyurethane finish keep the interior of these vessels waterproof, or do I need to go with one of the marine variants, or even an epoxy coating?
Since these will be given away for Christmas presents I don’t have any clue whether the recipients will use them for dry arrangements, keep them constantly full of water, or even use them as wood goblets – I’d rather not have folks returning them or throwing them away because of cracks or leaks.
Any help would be more than I already have – I don’t feel like I have time to do the finish experimentation myself.
Thanks, Jim
Most finishes are non-toxic once fully cured.
As to which will stand up to continous water contact, 'don't have any experience that would allow me to speak authoritatively. I would guess the marine products would work(?)
I think poly will work as long as it remains intact. If it's scratched or worn water will get under it & eventually lift the film. I think I would use epoxy.
Jim,
Only a marine two part epoxy will form as waterproof a finish as you need, none of the conventional finishes are meant for continuous immersion.
While they are commonly used, these epoxies are not the easiest materials to work with and prior to curing are moderately toxic. They are also not cheap. You might want to consider a conventional finish and a note that the vessels are not to be used with water or else turn the vases to a size where a glass or metal liner could be inserted in them
John W.
Edited 11/7/2004 6:21 am ET by cleve
Jim I don't know what size these vases are, but how about making the internal hole the size of a 'standard' glass container. This will ALMOST assure you of a waterproof internal surface. I've seen wooden 'bud vases' made with a standard laboratory test tube in the central hole. Test tubes come in many different diameters and lengths. Your only job would be to find a source of them. Try checking with the Science Department at your local High School. They should have several different catalogs that list them. How about the plastic Cigar Tubes that the better cigars come in??
SawdustSteve
Thanks for the good insight from everyone.
My first thought was the non-toxic, waterproof finish, and my second and third were to find some prefab container to fit the turning and adapt the segmental glue-up to "capture" the container.
At this point I'm thinking of trying both approaches - no, I'm not one of these purests that try to build sinks and bathtubs out of wood. Since I know the planning and cutting and glue-up will be the greatest portion of time, and I don't have any "suitable" container ready at hand, I'm trying to allow for my overly optimistic view of how fast the entire process will go. It looks like the production will be something more than 8 and less than a dozen, all roughly 10 inches high, so that's a big whacking bunch of segments to get decided on and cut before the glueing starts.
Thanks again for everyone's helps and good thoughts.
truly, Jim in Saint Louis
Short of encapsulating the insides with a thick epoxy coating, nothing will permanently exclude water. Two coats of polyurethane finish will only exclude water and water vapor penetration for less than a few days.
For wooden vases, I would tell the recipients only to use them for artificial flowers.
